Results 1 to 25 of 25
    Reputation: socalrider77's Avatar
    avid juicy 3 squeal
    ok well this has been bothering me for quite a while now. my avid juicy threes squeal whenever i use them, but only the front. i have centered the caliper and have wiped the rotor with rubbing alcohol. how do i fix this? here is a video of what it sounds like:
    GoPro Mountain Biking FAST Dowhill : Cactus Run w/ Josh - YouTube
    2014 Giant Trance 27.5 3
    Chamois Dropper
    Reputation: natzx7's Avatar
    Sounds like your pads might be contaminated. I would probably try a new set and see if it goes away.
    2008 GT Force
    Go Veg
    29er
    best advice, get rid of them
    i had them
    even the cheapest shimanos are light years better
    Quote Originally Posted by Dan GSR View Post
    i had them
    I've thought of that but I'm only 17 and don't have a job so don't have the money to replace them. And until I have them, I think they will be fine and then I will be going to slx
    Sent from my iPhone 4s using Tapatalk
    Quote Originally Posted by natzx7 View Post
    Newb question, but are any pads good?
    29er
    real problem is you will spend so much money trying to fix them, in the end they will still suck
    can spend $130 on new shimanos, and be done with it
    Reputation: EmbraceTheHate's Avatar
    Sep 2012
    I got juicy 7s they make a little noise after using them alot. I dont see the big deal.....although i heard organic pads help.
    Sent from my DROID RAZR using Tapatalk 2
    Reputation: tucoramirez's Avatar
    Organic pads tend to be quieter.Do the brakes function properly? if so I would not worry about it.I will not buy Avid brakes, they have a poor rep.I am curious if the main complaint most folks have is just about noisy brakes or do they perform poorly? You may be better off with this? BlueSkyCycling.com - 2011 Avid BB7 Disc Brake Combo Kit
    29er
    when i had the juicy 3
    i felt it was harder to modulate than my current shimanos
    also the shiamno brakes have more power
    Reputation: phoenixnr's Avatar
    Jagwire sintered pads. No howl even when wet and last forever. YMMV
    "So I'm packing my bag for the misty mountain.."
    Sep 2012
    Quote Originally Posted by tucoramirez View Post
    They work great thats why they come on high end bikes. Some squeal some don't. All my buddies have avids.
    Take the pads out and clean them with alcohol, couple of time with brush and rag. Retighten your disk's screw to the hub.
    Quote Originally Posted by EmbraceTheHate View Post
    My Shimano hydras squeal when wet...so what? I guess I am not very sensitive to this type of issue,my car brakes squeal sometimes too of course the problem is amplified riding a rig with no motor or noise insulation.
    Reputation: Dgage's Avatar
    Put some auto anti squeal on the back of the pads. Its cheap and easy enough to do.
    Friends don't let friends cheer for the TML
    Brakes function good just wanted to see if it could be fixed. Thanks for all of the help guys!
    Jun 2010
    My fix for the squeel was to chamfer the leading edge of the pads.
    Quote Originally Posted by MitchD View Post
    What did you use?
    Jun 2010
    Dremel with a sanding drum, sandpaper would work just as well
    Sep 2012
    Lmao now mine developed a howl, while riding. If I pull the lever in just a bit it goes away. Only on the front though.
    I'm about to order new front rotor and organic pads front and rear. Hopefully that takes care of it.
    Let us know if that works
    Sep 2012
    Quote Originally Posted by socalrider77 View Post
    Well so far not good lol. I put a alligator serration on the front with alligator organic pads. Well it rubs a little bit, just enough to make noise.
    The rear I put a avid g3 with the alligator organic pads. It rubs as well. I'm assuming its the pads.
    I'm going for a ride this morning. Hopefully put enough miles on the pads to stop the rubbing.
    Quite a few riders I know change to another brand or learn to live with the squeal.You might try truing the rotors by hand or with the Park rotor truing tool.Good luck.
    Sep 2012
    Hey the squealing stopped but they rub. Just need to bleed a little fluid out and they will be good. Brakes awesome to.
    Sweet. What pads did you get?
    Sep 2012
    Alligator organic I posted what I put on in a earlier post.
