Results 1 to 6 of 6
    Ricky Bobby
    Reputation: mville_mtnbiker's Avatar
    Aug 2005
    Avid hydraulic disc brake question
    I bought an 8" Avid G2 brake rotor and I want to use it with an Elixir R front brake. I also bought a 7" Avid G3 brake rotor to be used in the back. But, it will be used with a Juicy 7 rear brake not an Elixir R rear brake.
    Is that going to work?
    Or put another way; can I use G2 and G3 rotors with an Elixir R and Juicy 7 setup, respectively?
    Ricky Bobby
    Aug 2005
    Nevermind
    I'll just run it this way and if it works, it works. If not, then, hey, at least I'll know the answer!
    Jul 2003
    Avid only makes....
    three different rotors, the G3 clean sweep, G2 clean sweep and the Roundagon. All of their rotors are compatable with any of their brakes, no worries. Now mixing and matching of Avid brakes with rotors from other manufacturers can be problematic. But as long as you are using Avid rotors they'll be compatable with your brakes.
    Good Dirt
    Riding free's the mind
    I thought I read somewhere that G2's are for Juicy and Code brakes. G3's for Elixirs. Not sure if it matters which you use as long as the pads engage the right part of the rotor. G3's have a nice design for what it's worth
    Question to a custom frame builder..."So what makes your bikes climb better?"....his answer, "Uh, your legs?"
    huffin' n' puffin'
    Reputation: momotaro's Avatar
    I use hayes V8 rotors with juicy 7's on my DH bike...oh the horror! j/k
    Jul 2003
    Quote Originally Posted by HTail
    The G3 is actually a replacement for the G2. The G2 will eventually be phased out. And the Codes are still coming with G2 rotors. The only brakes that come stock with G3s currently are the Elixer and Elixer CR models.
    Good Dirt
