Results 1 to 9 of 9
    Reputation: dangerDan's Avatar
    Avid/Hayes rotors on Shimano center-lock hubs?
    Is it possible to put non-Shimano rotors on Shimano center-lock disc hubs? It looks like it would require an adaptor to mate the 6-hole rotor mount to the piece that mounts to the center-lock hole of the hub.
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    i'm not aware of any adapter that allows you to do this. Depending on the brake you can use a shimano rotor.
    Feeding your addiction
    Reputation: Ventanarama's Avatar
    Dec 2001
    Quote Originally Posted by mtb_biker
    There's one coming, but it's not available yet. Just noticed this weekend that QBP is now showing a "Problem Solvers" one on their website. Pic attached.
    Larry Mettler
    http://www.mtnhighcyclery.com
    Aug 2005
    This is now available and works well
    https://www.starbike.com/php/product...blNaben&id=397
    Strongbow or Bust!!!!
    Reputation: The Tractor's Avatar
    DT Swiss makes this adapter..........
    http://www.dtswiss.com/index.asp?fus...kedetail&id=31
    And you can use your Avid disk with it.
    Rob
    Fermented Apple Juice rules!!!!!! BURRRRPP!!
    Aug 2005
    The excitements killing me
    Reputation: Hardtails Are Better's Avatar
    May 2005
    Quote Originally Posted by The Tractor
    Rob
    The DT one has been avaliable for a while, and it works well. Give it a shot.
    Apr 2005
    The DT adaptor works awesome
    Rob
    A good friend of mine just installed a set of them on his hubs. He read this article before buying, and it convinced him (R. Cunningham wouldn't steer you wrong):
    http://www.mbaction.com/detail.asp?id=1163
    Then he threw a set of these rotors on http://www.dirtydogmtb.com/skull.html
    "El Whatever"
    Reputation: Warp's Avatar
    Magura sells some centerlock adapters ... but their website does not indicate if it's Problem Solver ty pe or DT type... you can ask them first... price is 25 bucks a wheel.
    Check my Site
  1. Why use shimano hubs?
    By thebronze in forum Wheels and Tires
    Last Post: 07-18-2004, 04:16 AM
  2. Replies: 2
    Last Post: 03-17-2004, 10:27 AM
  3. cone wrenche size for Shimano hubs
    By PBK in forum Tooltime
    Last Post: 02-17-2004, 01:44 PM
  4. Replies: 4
    Last Post: 02-12-2004, 10:55 AM
  5. Replies: 2
    Last Post: 01-28-2004, 03:00 PM
