Results 1 to 3 of 3
    Avid front brake adapter question
    I want to upgrade to a 185 rotor up front. I see that the adapter for my rear brake says 140 rear/160 front, so if I had an extra 160 rear brake adapter, logic tells me it would be 160 rear/185 front, right? I can't find anything about this online. Also, its the standard 51mm mount on the front, not 74mm post mount. I tried searching forums, you get a lot of results when you search "160 rear 185 front adapter", so I was hoping somebody knew the answer off the top of their heads. If nobody knows, I guess I can just install it and see if the pads are hitting the rotor corectly.
    Thanks, Alex
    dirtbag
    Reputation: ranier's Avatar
    Sep 2003
    You match the adaptor to the rotor size you want to run therefore, you'll need a 185 adaptor to run a 185 rotor.
    Amolan
    I think he was looking for an answer about whether or not a adapter marked "160 rear" will work in place of one marked "185 front", consdering that some adapters are marked "140r/160f"
    Your logic sounds correct, IDK if it will actually work or not, maybe you should just try it out.
    -Connor
