    Reputation: iwantalitebike's Avatar
    avid elixur pad question
    I have a set of Avid Elixur CR, and its time for some new pads. Which is the perferred pad, the sintered or the organic pad. I have the G3 cleansweep rotors and i need a little clarification. Thanks in advance
    I ride a bike, therefore I am!
    Always stick with metal sintered. Never go organic unless you're going some easy XC with just little downhill.
    Organic pads will be gone after a few wet rides. I tried a pair of organic back in February. It's all used up down to the metal backing plate in less than two months.
    Sheffield,South Yorkshire
    Reputation: ibbo's Avatar
    Sintered is the way to go.I've trashed an organic set in less than 15 miles in the wet and gritty UK.
    thanks, i will get some sintered pads
