Results 1 to 2 of 2
    Dec 2009
    Avid Elixir CR Question
    In the manual it says if any adjustments to brake hose routing are needed loosen the banjo bolt nut and adjust as needed. However they didn't say if they would need to bled after doing so. Anyone know if they will need to be bled after an adjustment?
    Here is a picture of the bolt in question:
    Reputation: madskatingcow's Avatar
    If you only loosen the bolt just so you can adjust it to your preference, no need to re- bleed the brake.
