    Avid Elixir CR Contact Point Adjustment
    I just got some new CRs and I can't get the Contact Point Adjustment barrel to rotate. I'm turning it pretty hard but don't want to break it. Is there a trick to it?
    Thanks.
    Reputation: onegymrat's Avatar
    Pull the rubber boot down to expose the silver metal thing. Hold that silver part with one hand while rotating contact pad adjustment barrel with the other hand. This will not allow the whole hydraulic hose to rotate, which is the common problem. When satisfied, simply slip the rubber boot back on. Voila!
    Hope that made sense.
    Got it. Thanks for taking the time to help.
    Aug 2010
    I had a similar problem... had rotated the adjustment in and then it wouldn't go back out. This thread's solution helped with that, too.
