Results 1 to 7 of 7
    Fox Shox
    Reputation: thredbo's Avatar
    Jan 2013
    Avid Elixir brake pad replacement issue
    When I went to replace my worn out Avid Elixir 5 brake pads, I got the old pads out and the new pads in easily enough, but there is only a tiny gap between the new pads, not even enough to fit the rotor into. I tried wiggling them around etc. but they were still too close together to fit the rotor into. Why is this happening? This is the first time I have tried replacing elixir's, so am I somehow doing something wrong?
    If i go to hell i'm taking my mountain bike.
    Reputation: ghettocop's Avatar
    You need to push the pistons back into the caliper. Use a tire lever or similar device. If they will not retract fully, release a small amount of fluid from the system.
    Reputation: gmats's Avatar
    Apr 2005
    Yes, as previously stated. Put your old pads in, get a decent size screw driver and pry the "old" pads apart to push the brake caliper pistons into the caliper.
    Install the new pads and the wheel. Slowly and gently pull the lever a few times to allow the new pads to seat on the rotors. Hopefully that will be it. You may have to "recenter" the caliper if the pads don't move "evenly".
    Good luck with that, post back here and let us know how it went.
    Apr 2005
    Also, if you have made any adjustments at your levers, undo those before you try to push the pistons back in. I struggled with this for more than an hour the first time I changed my pads. Once I backed off the reach adjustments I made earlier, the pistons went back in all the way.
    Jun 2010
    Remove the pads and use a tire lever to push the pistons back and then insert the bleed block until it fits in the notch at the bottom. Pump the levers if they are extremely tight let a little fluid out of the calipers and re-pump the brakes. Be sure to properly "bed in" the new pads.
    Also check for stuck pistons by gently pumping the brake lever and watching the pistons. The pistons should move freely. CAUTION: Do not pump them out so far that they fall out. If one of them is stuck you may be able to lube it with some recommended brake fluid around the piston. If it is stuck and lubing doesn't help then you should re-build the caliper. See Avid's site for more info.
    Metrology has nothing to do with the weather.
    Reputation: Poopshute's Avatar
    Quote Originally Posted by authalic View Post
    Sorry to revive an old thread but the quoted post above helped me a ton. I have Juicy 3's and just replaced the pads. Had the same issue as the OP for my rear brakes and after many attempts to adjust the calipers and pinch the pistons, I realized that something as simple as LEVER reach was causing the pistons to not fully retract all the way. After moving the lever closer to the grips, the rear pistons retracted fully and I was able to properly align the caliper with no rubbing. I then re-adjusted the lever reach back to where I like it and all was well. Thanks for this helpful post!
    May 2015
    Quote Originally Posted by Poopshute View Post
    +1 from me too - I spent 2 hours googling this, watching youtube and generally scratching my head, before seeing this post. I am utterly AMAZED that this is not mentioned in the single page instructions that came with the elixir pads, or on their official posted videos. Once I had backed out the adjuster screw that changes the position of the brake handle, both pistons went back in without any struggle at all. Before that I could push one piston in, and the other would push out, and nothing I could do would get them both out, and I forced it very hard to in desperation. So thanks for the above posts.
  1. Avid Elixir 3 Issue
    By yodeiu in forum Brake Time
    Last Post: 09-21-2013, 03:45 PM
  2. Another Avid Elixir brake issue
    By allroy71 in forum Brake Time
    Last Post: 08-02-2013, 04:59 AM
  3. Avid Elixir CR Brake Pads Replacement
    By defuentes in forum Brake Time
    Last Post: 05-08-2013, 02:21 PM
  4. Avid Elixir issue
    By SoFlaBiker in forum Brake Time
    Last Post: 09-12-2012, 08:22 AM
  5. couple questions on replacement brake pads for Avid Elixir 7
    By Sleevem1 in forum Beginner's Corner
    Last Post: 09-03-2012, 07:25 PM
