Results 1 to 5 of 5
    Reputation: targnik's Avatar
    Jan 2014
    Avid Elixir 9 Trail & Shimano M615's??
    650b bike has Shimano M615's w/ 180 Shimano rotors...
    29er has Avid Elixir 9 Trails w/ 180mm rotors also (brand = unsure)...
    Can I successfully swap brakes over from one bike to the other? (keeping rotors where they are)
    T.I.A
    #1 resolution... Ride it like I stole it!!
    "Mountain biking: the under-rated and drug-free antidepressant"
    Reputation: Mr Pig's Avatar
    Maybe. Shimano rotors can have quite a narrow brake track so you need to watch the fit. If the pads overhang the arms on the inside of the track it'll be ok. Overlap at the outside is...bad.
    Shimano brakes usually fit on other brand rotors just fine.
    Feb 2016
    maybe is right. assuming the OD of the rotors is the same, and there is no difference in offset. I'm assuming there is none if talking about two six bolt rotors, they may follow a slightly diff plane if swapping between centerlock-6bolt from one bike to the other. totally guessing, i have no idea and no way to measure.
    assuming there are no such interference problems, i would say that the narrower shimano pads might work on the wider avid rotors, but you may have a wear issue using the wider avid pads on the relatively narrow shimano rotor.
    Jan 2014
    Quote Originally Posted by turmoil556 View Post
    10x have gone ahead and swapped them over (front initially to see if it works)...
    All seems ok at the mo... little adjustments needed before tightening down.
    Spanner called in for a little rotor straightening.
    Avids are a little snug on the Shimano rotors. Which is weird as all rotors are roughly 2mm in width!?
    Can always change em back if they don't play nice ;-)
    Quote Originally Posted by targnik View Post
    Shimano brakes have more pad clearance and maybe the Avids are starting to seize up. They do that.
    There are slight differences in the thickness of rotors. Shimano rotors are 1.8mm thick but some others are 1.75 etc. I use Formula rotors on my bike with bigger rotors because they are thicker. They are noticeably stiffer and less likely to get bent.
  1. Replies: 7
    Last Post: 06-29-2015, 05:19 PM
  2. Shimano XT Vs Avid Elixir X9 trail
    By mo6500 in forum Brake Time
    Last Post: 02-27-2014, 12:58 AM
  3. Avid Elixir 9/XO or Shimano XTR
    By Island20v in forum Brake Time
    Last Post: 08-08-2013, 07:39 AM
  4. Shimano SLX or Avid Elixir?
    By A Ton of Clay in forum Brake Time
    Last Post: 08-11-2012, 06:50 AM
  5. Replies: 6
    Last Post: 01-26-2011, 07:42 PM
