Results 1 to 5 of 5
    Apr 2013
    Avid Elixir 5 Rotor Change?
    Hi guys
    I'm planning to upgrade my avid elixir 5 rotors soon, I've seen some that I like the look of. The front rotor at the moment is a 185 Avid HS1 iS, but the range I'm looking at only has 180s. Thats fine for the back, but will a smaller rotor fit and work on my bike? The fork is a Fox F-Series 32 RL 120.
    Thanks in advance
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    You can use whatever size you want so long as you have the right adapter. If you are going from 185 to 180, you're going to need a new adapter as well.
    Apr 2013
    Thanks, any ideas where I can get one for my brakes?
    007 is offline
    b a n n e d
    Jun 2005
    Any of the myriad online vendors, or better yet, your LBS.
    Apr 2013
    I'll give them a try. Thanks
  1. Avid Elixir CR rotor rub
    By Mr. Jimmy in forum Brake Time
    Last Post: 08-01-2012, 03:39 PM
  2. Avid Elixir 1 Rotor Upgrade
    By Kinetic07 in forum Brake Time
    Last Post: 07-19-2012, 10:04 PM
  3. XX rotor + Avid Elixir
    By marcryan27 in forum Brake Time
    Last Post: 08-26-2011, 08:54 PM
  4. Avid Elixir CR pad / rotor question
    By iwantalitebike in forum Brake Time
    Last Post: 07-26-2011, 04:30 AM
  5. New Elixir rotor. Should I change pads too?
    By martinizer in forum Brake Time
    Last Post: 07-21-2011, 08:21 PM
