Avid Elixir 3 problem
I have white Elixir 3 brakes that are brand new. After I bed them in, the rear brake has good power, but it has a very gritty feeling, as if there is sand somewhere even though that is impossible. It also makes a sound like there is sand scratching the pads. What could be the problem? What problems can emerge from braking too hard while bedding in? Thanks
Maybe your pads got glazed from too long a stopping attempt before they were bedded in. Try sanding them and re-bedding them.
I will try removing the brake pads and sanding them a bit and bed them in tomorrow. Thanks for the help!
By bweide in forum Brake Time
Last Post: 01-26-2013, 06:53 PM
By Bppennick in forum Brake Time
Last Post: 08-14-2012, 05:18 AM
By torosc in forum Brake Time
Last Post: 11-03-2011, 06:02 PM
By expatrider in forum Brake Time
Last Post: 04-01-2011, 09:18 AM
By Snackie in forum Brake Time
Last Post: 01-28-2011, 02:20 PM
- You may not post replies
- You may not edit your posts
Forum Rules
