Results 1 to 2 of 2
    Avid ELixir 1 adapters
    I am looking to put a used set of Elixir 1 discs on my old trek. I have an IS fork and am not sure on what adapters I need to get to make these work?
    B A N N E D
    On this page # 6 for 160mm, # 7 for 185mm and # 10 for 203mm.
    Avid now makes 180mm and 200mm rotors.
    For the 180mm rotor you'll need the 20mm IS adapter like this.
    For the 200mm rotor you'll need the 40mm IS adapter like this.
    Avid also has a 0mm IS adapter which is the same as a the old 160mm front / 140mm rear IS adapter.
