Results 1 to 5 of 5
    Reputation: Noclutch's Avatar
    Jun 2010
    Avid Elixer 5 rear pads toast
    So I've gone through my OEM rear pads now at about 40 hours and need to replace them. In shopping around I see several brands- Avid, Ebc(maybe?), Jagwire and Koolstop.
    Prices are all close except that the Avid's are 50-100% more expensive than the others, and freaking expensive for the amout of material there!!
    I'm not downhilling, ride XC mostly with some technical bits, but admit to being a brake-dragger the rear in the faster curvy stuff a bit
    Suggested pads? Is the aftermarket as quality stuff as OEM?
    Thx
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Always get OEM. Why risk voiding your warranty?
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    My experience is the aftermarket and the OEM pads for Avid are practically the same.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Noclutch
    Thx
    OEM does not mean they work the best. I have found the Avid branded pads to be inconsistent quality in the past.
    EBC pads have been very good for me, but I do not know which compound is best for your model brake.
    Using aftermarket pads will not void the warranty.
    mtbtires.com
    Never trust a fart
    Reputation: frdfandc's Avatar
    If you are using the standard metallic Avid pads, then the organics will last 1/2 as long.
    At least stick with the metallics since you are a brake dragger. I've had good luck with the Avid branded stuff, but like Shiggy said,can be inconsistent.
    Here are a few manufacturers.
    EBC
    Avid
    Goodridge
    Jagwire
