Results 1 to 2 of 2
    Avid Elixer 185mm rotor hardware
    I got a deal on some avid elixirs, but they're missing the hardware. I have all the conical washers and such, but i still need the actual bolt. Talking to a tech at the LBS, he says i should be able to pick these up at the local hardware store.
    How long of a bolt should i be getting? and what threads per inch should i be looking for? (do i even need to worry about this?)
    I've been able to find the kits for sale but nothing with specifications for the 185mm rotor adapter.
    Thanks.
    Jun 2010
    M6X1.0 ,one bolt is 40mm and the other is 45mm. Good Luck, I would order the bolt kit from Avid first
