Results 1 to 5 of 5
    Avid DIY bleed kit
    Anyone make their Avid bleed kit? I use a vacuum pump to bleed my car brakes and I think it'd work better then the syringes and wouldn't cost so much. I guess I really just need to know where to get some of the correct bleed fittings. I haven't found where to buy them separate from the kit.
    Yup. Dirt cheap too.
    Considering how small the brake system is, I wouldn't bother with a vacuum pump. But if you try it, post how it goes.
    home made avid bleed kits
    Thanks for the link. I have a vac pump and it seems that it would be easier to pull new fluid through the brakes then using the syringes.
    The syringes you can get from a pharmacy cheap. Just be upfront with them and they will sell them to you and not give you the eye-ball thinking you are a druggie.
  1. Replies: 0
    Last Post: 05-31-2011, 08:28 AM
  2. Avid Bleed Kit
    By danny_mcgee in forum SRAM
    Last Post: 09-18-2009, 09:27 PM
  3. Anyone bleed Juicy 7's without the Avid Bleed Kit?
    By IRONMAN1518 in forum Brake Time
    Last Post: 02-01-2009, 08:36 PM
  4. Avid Bleed Kit????
    By Monk_Knight in forum Brake Time
    Last Post: 12-01-2008, 10:46 AM
  5. Avid Bleed Kit
    By danny_mcgee in forum Tooltime
    Last Post: 10-03-2007, 10:14 PM
