    Your bike sucks
    Reputation: Carl Mega's Avatar
    Avid Disk pad rattle - can it be fixed?
    I have an older (165) Avid disk brake that is driving me crazy. The pads rattle and the noise is getting to me. I don't think they were this bad before. Anyway -> I know the newer ones don't have this problem and I can't remember if changing to new pad (better magnet?) will help correct this. My pads have plenty of wear left but I'd be willing to sacrafice them inorder to have some peace and quiet.
    I don't frequent this forum much so if i asked a common question just gently put me in my place.
    Quote Originally Posted by Carl Mega
    The older V1 calipers had a problem w/ the magnets breaking and coming apart over time. Magnets are no longer availiable according to Avid. Avid sells clips but I think it is in a 10 pack. I'd just buy pads w/ clips and run the new and old set on the same clips. Some pads have material that is too wide for the clips but I have found a little trimming w/ a file sovles this problem.
    Do It Yourself
    Reputation: Homebrew's Avatar
    I had the same issue with mine. A new set of pads with clips solved the problem. If you contact Avid, I'm sure they will send you a clip for free. As keen mentioned, you will have to do a bit of filing to get the clip to work with your old style pads. It will save you 25 bucks for new pads though.
    Aug 2003
    Get some new pads
    Quote Originally Posted by Homebrew
    Make sure you get Avid brand pads.I have had no luck with the aftermarket ones,its worth paying a little more to avoid the headache.Pick out the old broken magnets with a small screwdriver or similiar small sharp device.Then snap in the new pads,readjust the caliper and go ride!!
  1. Avid brake pad replacement alternatives?
    By jdcamb in forum Brake Time
    Last Post: 07-03-2004, 10:39 AM
  2. Avid pad wear question
    By rpet in forum Brake Time
    Last Post: 03-14-2004, 06:43 AM
  3. Avid disc brake pad removal
    By Pigtire in forum Brake Time
    Last Post: 03-02-2004, 09:14 PM
  4. avid mech rattle
    By toe-knee in forum Brake Time
    Last Post: 02-21-2004, 07:34 AM
