    Kam is offline
    A hopped on pop.
    Reputation: Kam's Avatar
    Avid discs with a Rollamajig???
    I have used Avid discs in the past. I really liked the power, but the rear brake seemed vague with no modulation. Has anyone tried using a Rollamajig with the Avid dics? Any tips on getting the smoothest feel out of the system? I'll be using them with Avid SD 7 levers and maybe the Avid Straight Jacket cable systems, with full length housing.
    I don't really see why you'd need a rollamajig for the mechs. there's no 180 turn in the cable like there is when on the rear derailleur.
    On MTBR hiatus :(
    Plastic construction...
    Quote Originally Posted by Kam
    I dunno, man -- I've heard of guys running 'em on their V's, and it is only your rear brake, so it might be worth experimenting, but plastic construction -- I dunno, man...
    Reputation: SDizzle's Avatar
    Did you see this?
    Chameleon disc fix (x-post SC)
    There's no sense in using a Rollamajig unless, like other said, you've got a really steep bend in cable (ie, 180*). It doesn't 'smooth things out'--that wasn't its purpose for derailleurs, either.
    "I've courted brain damage like some courtesan of darkness."
    -The Good Doctor
  1. Brake Cables for Avid Discs?
    By 2big2ride in forum Singlespeed
    Last Post: 03-09-2004, 10:35 AM
  2. Avid + SRAM = ?????
    By FLOMBE in forum Brake Time
    Last Post: 03-02-2004, 10:34 PM
  3. weight/peformance of v-brakes vs. discs
    By jcospo in forum Weight Weenies
    Last Post: 02-21-2004, 11:04 PM
  4. Help w/ replacement rotors for Avid Mechs
    By ThornPatch in forum Brake Time
    Last Post: 02-03-2004, 02:23 PM
  5. Replies: 1
    Last Post: 01-13-2004, 10:47 AM
