    Just Ride!
    Reputation: Pigtire's Avatar
    Upset Avid disc brake pad removal
    I am having a hard time removing my Avid pads from my mechanical disc. I followed the instructions listed(hold tabs together and pull down) but it won't budge. Am i missing something here?
    Try this:
    Quote Originally Posted by Pigtire
    Try rotating the pads towards the front and/or rear of the caliper. There are two tabs that hold them in but one side is supposed to come out easier. This should work. I know it has for me.
    Official ***** Idiot
    They seat in there kinda tight, it may take a bit of force to pull them out.
    You can use a pair of needle-nose pliers to pull them out, if need be. Just make sure the backing plate is clearing the caliper body. Sometimes mine come out relatively easy, other times I have to use pliers.
    Just Ride!
    Hah! Got it out. Thanks for the info guys
  1. Adding Disc brake tabs
    By Dirteye in forum Brake Time
    Last Post: 05-12-2004, 01:06 PM
  2. Replies: 5
    Last Post: 02-24-2004, 04:44 PM
  3. Avid road disc brake for mtb
    By K2footsrgn in forum General Discussion
    Last Post: 02-17-2004, 01:54 PM
  4. Avid road disc brake for mtb
    By K2footsrgn in forum Brake Time
  5. Need disc brake adapter for manitou 74mm to 51mm
    By DIYguy in forum Shocks and Suspension
    Last Post: 01-18-2004, 08:05 PM
