    11 is one louder than 10
    Reputation: Green Giant's Avatar
    Avid CPS bolt size?
    Does anyone know the exact bolt size for the AVID CPS bolts (bolt that mounts the caliper to the frame mount). I think it is a m5 or m6 x 30... anyone know for sure?
    Thanks.
    "The thing is, Bob, it's not that I'm lazy, it's that I just don't care."
    I love Pisgah
    Reputation: Duckman's Avatar
    6m x 25mm if I remember right. Measure your steel ones. 1" is almost exactly 25mm(and I almost wanna say that I once made the observation that even 20mm lengths would work). I ran alum for those(on the front) for about 6 months with no probs fwiw. That bike now has v-brakes.
    Thanks.
    Yup, thinking M6 by 25 or 30mm. I'm thinking that Ti bolts would work well here. I'm taking some Ti bolts from my Mag Pluses, and looking at others to see how much weight could be saved on the Juicy 7's. just got them, but they are pretty darn nice thus far. Weight seems to be the only drawback. At 200lbs, I only try to save weight where it isn't stupid light.
    Te mortuo heres tibi sim?
    Quote Originally Posted by Green Giant
    I'm using ti bolts on my Avids, three bikes front and rear worth. M6 x 20 on the frame------>adapter/mount bolts, and M6 x 30 on the caliper/CPS bolts.
    One setup is new, one setup in use for about two years, and one close to three years-swapped from frame to frame in that time. No problems. Though I weigh in at about 60# less than you. Just use some good anti-seize, and don't overtorque. I've actually stripped a bolt head on one (doh!) before the threads came even close to stripping.
    FWIW, I've used www.racebolts.com for bolt needs. Good prices, fast on the shipping.
  1. Welcome, here's your 29er FAQ thread!
    By ncj01 in forum 29er Bikes
    Last Post: 06-20-2012, 01:56 PM
  2. Replies: 0
    Last Post: 10-03-2004, 06:08 PM
  3. bolt size for brakes?
    By donkekus in forum Weight Weenies
    Last Post: 09-17-2004, 08:25 AM
  4. Wanted: Avid CPS 160/165 Rear Bracket
    By Fattirewilly in forum Brake Time
    Last Post: 08-13-2004, 05:55 AM
  5. Will Avid Mech work with Coda 4 bolt rotors?
    By Edderd in forum Brake Time
    Last Post: 06-06-2004, 02:44 AM
