Results 1 to 5 of 5
Thread: Avid Code Issue
    Reputation: B-Mac's Avatar
    Avid Code Issue
    I have Avid Codes on my Turner Highline. Older codes btw. I changed pads this morning (rear caliper) - spread the old pads with a flathead screwdriver (they were not worth saving) and replaced with new pads. When I reinstalled the rear wheel, I had zero lever. In fact, it feels like there's no engagement with the piston whatsoever. Lever just flops around loose.
    I bled the system back in early september. Any possibility it just needs bled again?
    Any ideas appreciated, thanks.
    T.W.O.
    Reputation: mimi1885's Avatar
    First off, check if your rear wheel is fully install. It happened to me a few times when installing rear on the stand. It took a few pumps to take the lever pressure up. Hope your problem is just as simple as mine
    Yep, installed.
    if the lever just flops, then the o-rings of the master cylinder are toast, and should be replaced (avid sells only the entire master cylinder assembly, though).
    Solved the problem using a tip from this thread:
    Avid Code lever piston stuck
    The piston was stuck. Sounds like some plastic part on the piston swells after time? I removed the hose from the lever, pushed the piston back into place with an allen wrench, bled the system & that fixed the problem.
    I think it stuck down in the first place because, having just spread the pistons as far as possible to replace the pads, I pushed the piston deeper than usual causing the swelled plastic thingy to catch on something.
    Thanks to folks who responded with advice.
