Results 1 to 5 of 5
    May 2010
    avid bolts dimensions..
    Need your help guys..
    What's the length of the 2 CPS bolts for the 185mm PM to PM adapters?
    And what's the length of the small bolt for the rear IS adapter to frame?
    I should think they're M6 bolts but I'm unsure of the length..
    Thanks in advance!
    ballbuster
    Reputation: pimpbot's Avatar
    Yep, M6 bolts. Don't know how long. Speedgoat.com sells the complete CPS kit for $3. I say just order them, unless you're in a pinch and need it up and running ASAFP.
    I just ordered two kits myself.
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    Quote Originally Posted by n.e.r.d
    Thanks in advance!
    I had to locate some temporarily while waiting for the real kit to arrive.
    The bolts are different lengths.
    One is about 50mm the other about 45mm.
    Like pimp says, just order the kit. I went to 4 different hardware stores looking for the bolts. In the end I had one with a hex head, the other a regular socket head. The longer one I could not find in hex.
    May 2010
    I'll order the bolts for the front adapter, but the CPS hardware does not include the small bolts that attaches the rear adapter to the frame right?
    What is the length of that small bolt?
    aka dan51
    Mar 2005
    Those are the standard brake caliper bolts. Nothing special about them.
