Results 1 to 2 of 2
    Reputation: skibum1's Avatar
    Jan 2005
    Avid Bleed Block?
    Hey guys. I'm about to do the unthinkable. Bleed my Juicy Ultimates. Gulp. Been reading over the manuels and it keeps mentioning putting in this "Bleed Block" to where the pads are/were after I remove the pads to prevent the solution from getting in there. Where the hell do I even get a Bleed Block from? It didnt come with the Avid Bleed Kit. Is this something a lbs should have? Is it even necessary? I just want this nightmare to be overwith. Thanks.
    mbtr member
    Reputation: scottzg's Avatar
    just stick something between the pistons so you don't push them out. You can use a pen.
    Bleeding avid brakes is a walk in the cake.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
