Results 1 to 2 of 2
Thread: Avid BBDB noise
    Baby Bear is in the house
    Reputation: r1Gel's Avatar
    Bonking ... not feelin' well Avid BBDB noise
    I've had my Avid mechs for about 4 months now. Though they took a while to break in, they're pretty awesome now.
    My prob is, the rear has started howling. What could be causing this? Dirty rotor? I started using rubbing alcohol, swabbed with a cotton ball, to clean my rotors just last month. Would this have contributed to the noisy brake?
    Try this?
    Describing noises is always tough, but try this:
    take the pads out, and clean everything including the face of the pads and the springs etc. Then reassemble. Make sure to assemble and readjust per the avid instructions. If you don't have the instructions, download them from the avid website.
    http://www.avidbike.com/7_techinfo/tech7_2_manual.html
    Make sure your caliper is installed 1/3 and 2/3 per the instruction sheet. I once installed mine 2/3 and 1/3 and they squeaked/rubbed like crazy, but only at high speed. (18mph +). Good luck.
  1. Avid BBDB compatible with 2004 XT Disc Hubs?
    By suichai in forum Brake Time
    Last Post: 02-11-2004, 04:38 PM
  2. Caliper clearance with Avid BBDB and new fork?
    By mikeyjunior in forum Brake Time
    Last Post: 02-01-2004, 07:30 PM
  3. SID rear shock noise
    By dgangi in forum Shocks and Suspension
    Last Post: 01-26-2004, 09:01 PM
  4. having trouble mountain AVID BBDB brackets!
    By KamikazeBikr in forum Brake Time
    Last Post: 01-23-2004, 10:07 PM
  5. Avid Mech chirping sound help?
    By Murchman in forum Brake Time
    Last Post: 01-20-2004, 09:11 PM
