Results 1 to 5 of 5
    avid bb7's problem ?
    i was changing the pads on my bb7's and i cant get the silver thing on the wheel side to go back down....am i screwed?
    is it a p.i.t.a to get back in? here are some pics of what i mean....
    its like the little knob is just spinning, there is still a clik but the plate inside does not move...
    hope that makes sense,,,,
    Meh.
    Reputation: XSL_WiLL's Avatar
    Look up the BB7 caliper overhaul pdf.
    On MTBR hiatus :(
    speedub.nate
    MTBR Hiatus UFN
    OTTer
    Reputation: psych's Avatar
    Nov 2007
    thanks for the link - just had the same problem installing.
    Welcome to the Gem...
    Reputation: Mallanaga's Avatar
    Quote Originally Posted by That Avid site Linked above...
    The most common problem that doesn’t require disassembly:
    A common BBDB call we get is about a caliper with the outboard pressure foot dislodged. If the outboard adjustment knob is turned too far clockwise without the rotor in the caliper (wheel off or caliper removed), the outboard pressure foot can be pushed out of the drive cam and float free in the caliper body. The brake is not broken and it doesn’t need to be disassembled to replace the pressure foot.
    To replace the pressure foot, turn the outboard adjuster knob counter clockwise until it stops. If the knob doesn’t stop, then the footscrew (you can see the end of the footscrew in the center of the knob) has become disengaged from the knob, and possibly from the threads inside the drive cam. In this case, remove the knob, then use some small needlenosed pliers or a Schrader-valve tool to turn the foot screw all the way back out until it stops. Once this is accomplished the pressure foot can be replaced. Relocate the pressure foot into the bore, then give it a firm push in the center. It will “click” back into place.
    If you removed the outer knob, replace it, and you’re done!
    nice link. cheers!
    Ibis Tranny 29
