Results 1 to 33 of 33
    Reputation: robpad's Avatar
    Oct 2011
    Avid BB7 or Shimano Deore
    like the title says which is better, Deore's are a little cheaper but both are in the same price range. your opinions.
    all depends on what your looking for. what kind of bike would be a starting point. what kind of riding do you do? dh, xc, or freeride? competitive or weekend warrior?
    Oct 2011
    it's going on a 00 rockhopper fsr comp, do xc and freeride on weekends.
    Dec 2011
    Deore. Too many people (myself included) have had trouble with avids. Mine have been into the shop coming up on a half dozen times for constant squealing and turkey gobble in the rear. We're working on getting the rotors replaced under warranty ('12 bike with just about ~300 miles on it) - looks like I have to go to solid rotors.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by robpad View Post
    I have never had a reason not to choose BB7s.
    mtbtires.com
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    +1 for BB7
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    New Deores are the best budget brakes out there.
    Tried Avid years ago, and Deore are way better IMHO, let alone maintenance.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    +1 for BB7. Got a set of them on my SS, Elixir CR's on my FS and Juicy 7's on my HT. All of em have been trouble free and plenty 'o stoppin power for 195# rider with 160mm front and rear rotors.
    Feb 2012
    Quote Originally Posted by probiscus View Post
    probiscus,
    I noticed the post above you made about Avid BB7's and the "turkey gobble" sound they make. I have the same problem with my Tektro disc brakes and it is killing me not knowing what it is. They seem to work fine, but that chattering/squeeky/death sound is so annoying. Did you figure out what is causing it? It doesn't seem to be that the rotors are dirty and they stop great so the pads seem fine. It has my LBS stumped too.
    Sorry to hijack, I'm just very excited to be able to ask someone who is describing the exact problem I am having. I would have sent a PM but this is my first post and apparently you need 10. Thanks for your help!
    just to be clear, you are comparing the Deore V-brake vs the Avid Mech disc brakes, correct. The BB-7 would be a big improvement but you will then need to get rotors, hubs, etc. thus increasing the cost way beyond the Deore. Patch up what you have and save up for new bike
    Dec 1998
    I have been using BB7s since 2000 and do not know what is meant by turkey gobble. My brakes make noise from time to time but nothing outrageous.
    mtbtires.com
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    isn't there like 3 Deore's? V-brake, Mech and hydro..? kinda need to clarify which one.
    I'd still say BB7's WAY better than the Shimmy V or Mech.. close to a tie with the hydro's but I've seen tooo many wipeouts where brake lines and/or levers get damaged.. , too much time down getting parts, and the $$$ would really piss off my wallet. BB7's are soo common now anything you'd ever need pretty much any shop will have in stock and you'll be back on trail in 10 minutes, not 10 days. And with the $$$ you save you can get a new helmet to replace the one that just got smashed on the rock saving your skull
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Reputation: CharlesMTB's Avatar
    Please silence my Squeek
    I just upgraded my rear Disc to BB7. I read all good reviews on the brake and even read about their squeeling issue. Sure enough first ride after my install (very careful not to contaminate the rotor) they squeal LOUD right before lock out.
    I have read in many forums to wipe down with alcohol, sand down the rotors to remove the finish and even to change to organic pads. Is all that necessary, or should I ride the noise out, and see if it fades with a natural break in period.
    Reputation: lew242's Avatar
    Been using BB7 for years and Deore M596 for a few weeks. Deore M596 are slightly more powerful and have slightly better modulation. Really I prefer the short single finger levers on the Deores. The new Shimano range has lots of trickle down technology similar to SLX and the Deore are surpsringly good value, easy to bleed and one finger endos are a reality. However you can never go far wrong with BB7. Avid warble noises are mostly just caused by cheap rotors.
    SSolo, on your left!
    Quote Originally Posted by shiggy View Post
    Me three! BB7s are great mechanical brakes and the rotor noise is usually improper caliper adjustment and/or glazed pads. They will make some noise when they get wet.
    EDIT: The G3 Avid rotors are the only Avid rotors that I will buy, they stop better, self-clean better and make way less turkey gobble noise! Roundagons are the worst, G2 are ok, but G3 are way better.
    Get off the couch and ride!
    Feb 2012
    The Deore mechs are fine, I have been riding them for a few years without any problem; they are much better than BB5s (IMHO these should never be used in the front, only on road bikes). The Deores can only be used with organic pads though, there are sintered ones for BB7.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    ... Mine have been into the shop coming up on a half dozen times ....
    there's your problem right there
    Don't be an 'ahh, something minor is wrong - I'll take it to the shop!" kind of guy and fix it yourself.
    Honestly... ahh I give up
    Huckin' trails
    Reputation: David C's Avatar
    BB7. Or good hydro.
    But don't go cheap on the brakes.
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
    ~Disc~Golf~
    also, 'cheap' does not necessarily mean inexpensive
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    Deore Hydros would be my choice. Had two sets and never had a problem with them.
    Less isn't MOAR
    Huckin' trails
    Quote Originally Posted by highdelll View Post
    Yep, important point.
    Reputation: ZmyDust's Avatar
    I've used the flintstone method for the last 8 months and I've been happy almost the entire time. Pick one and enjoy!
    T.W.O.
    Reputation: mimi1885's Avatar
    Tru dat
    Mech brake I don't see any other model come close to beating overall performance/price/reliability of BB7. Hydro however, is another story
    Hi.
    I got installed my M596 with RT-67 180/160 rotors in December. Due to very warm winter i tested them a bit, more of in bedding in. I was surprised how responsive and powerfull they really are. The M575 that came with my bike really made hydraulics disc brakes look bad. The M596 are very decent brakes for this money. (=
    ~Disc~Golf~
    Quote Originally Posted by mimi1885 View Post
    Tru dat
    are you trollin'?
    (tryin to get a rise out of me?)
    ala mr. "frosty struthers'?
    T.W.O.
    are you trollin'?
    Trolling? Nah! I'm using BB7 and I like it set up front disc and rear V.
    Reputation: Fizio's Avatar
    Mar 2011
    Simple...best buy...Bb7...
    SANCTUS
    Reputation: BUSTELO's Avatar
    Feb 2012
    Never had any problems since 2004 with Avid BB7s when properly bedded in and set up right.I just started running Shimano Deore hydra calipers with dual control levers, so 2 out of three bikes are running shimano hydra.Only difference I see is slightly less maintenance since cables need to be kept top notch, and hydras are self adjusting. I find the modulation to be slightly better on Deore hydras.Organic BB7 pads seem to run quieter.
    SANCTUS
    Feb 2012
    Quote Originally Posted by thomllama View Post
    Feb 2012
    Oct 2011
    well I did it, just got a good deal on a set of shimano Deore mechanical disc brakes. $82, will be here next week. I'll keep you all posted on how they work.
