Results 1 to 10 of 10
    Reputation: RajunCajun44's Avatar
    Avid BB7 to replace Avid Elixir 1, Need to replace rotor ?
    I am going to replace my Elixir 1 brakes with BB7's, do I really need to change out the rotor too ? They are both 160mm rotors..
    B A N N E D
    Read Post # 6 and Post # 58
    Those were from this thread.
    Reputation: mitzikatzi's Avatar
    snip..
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    So the answer is... if I want to have even wear and better braking power, I should replace the rotors and not use the elixir rotors with BB7's...
    let me know if this statement is wrong... in any way... thanks,
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    I'd try the BB7's with the Elixer rotors and see what kind of stopping power and wear pattern you get. A little pad contact/wear on the rotor arm is not going to hurt stopping power.
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    Jul 2003
    Quote Originally Posted by MtbAZ44 View Post
    Totally depends on what rotor was speced with the brakes. If these are stock OEM E1's they almost always come with the G2 Clean Sweep rotors. All other Elixer models come with the HS1 rotor. The G2CS is the stock rotor that comes with a new set of BB7s as well. So you likely already have the G2 rotors. Take a look here and match up your rotors, Rotors | Avid | SRAM . If you do have the HS1 rotors, they can be made to work well with the BB7 caliper. It just takes a bit more fiddling to make sure the pads are hitting the rotors correctly, i.e. the pads aren't over topping the outside edge of the rotor. But before you get too worried about it, take a look at the link and see what you've got.
    Good Dirt
    My elixir 1's have the HS1 rotors. I tried the BB7's this morning with this rotor... Its hard to say if their would be an improvement with the rotor that came with BB7's unless I switch the rotors out and try that ride again..
    Dont Rep me
    Reputation: Strafer.2's Avatar
    I've used Hope rotors with BB7 for two years, then transferred the Hope rotors to a new frame with new Hayes stroker brakes.
    As long as the rotor size is correct, you should be able to mix and match brands/models.
    And as with new pads or rotors, braking power returns to normal after a couple of rides to bed in the pads/rotor.
    Removed wrong statement.. sorry guys/girls.. ...
    Am I allowed to back-pedal ? I actually tried the Clean Sweep rotor on a ride with steeper sections, and that rotor actually does make a difference over the HS1... The stopping power is better now with the G2 clean sweep...
    My apologies to anyone that felt like I suggested they were wrong...
