Results 1 to 3 of 3
    Feb 2007
    avid bb7 on new xtr rotors
    hi!
    can anyone tell me if d avid mechanical disc brake bb7 model works well on d new xtr rotors?
    pls help.i need some advice.
    thanks in advance...
    Meh.
    Reputation: XSL_WiLL's Avatar
    No. The braking path (blade) of the XTR rotors is too narrow. The Avid pads will sweep across the rotor (arms). This will cause uneven pad wear which will eventually lead to other issues. So unless you want to grind and bevel each set of pads to fit the rotors... I wouldn't do it.
    If you have centerlock wheels, just get the centerlock adapters and run 6 bolt rotors.
    Feb 2007
    xsl_Will@ thanks 4 the info.
