Results 1 to 9 of 9
    wannabe #1
    Avid BB5 disc rub
    Hi, I'm new here.. but my BB5's disc is rubbing when the wheel turns... what can I do to correct this, and what might be causing it?
    does it rub the whole rotation? if so, you probably need to adjust the caliper per avid's (sram's) instructions to re-center the caliper.
    if it just rubs in a certain spot, the rotor probably needs trued, which can be done with a CLEAN adjustable wrench
    Oh noes. I'm going to drink the Kool-Aid.
    Go to this site and do exactly what it says=problem solved.
    http://bluecollarmtb.com/2006/10/30/...l-disc-brakes/
    wannabe #1
    it only rubs in one spot
    then you have your anwser.
    wannabe #1
    well, this is my first set of real disc brakes... and I'm a little worried about screwing something up so bad I can't fix it... the LBS is 20 miles away in the next town... so I don't want to mess up.
    wannabe #1
    they stop really good, but I just don't like it rubbing my pads unevenly when I'm not trying to wear them down
    Aug 2005
    Check you pm
    wannabe #1
    Quote Originally Posted by MaddSquirrel
    Check you pm
    I haven't got anything, maybe you should try it again
