Results 1 to 3 of 3
    Its too warm here....
    Reputation: SenorPedro's Avatar
    Avid Arch Rival Q's
    I am looking at some rim brakes for my SS bike, its on a budget so I am going the rim route rather than discs. Now its been forever since I have used a v-brake. I have seen some Avid SD 2.0 V's for $15 per pair which probably would work just fine and match the budget nicely.
    I have also found some Avid ArchRival 4.0 brakes for $23 each, which seems to be a good price for these. Is there any real benefit between the two? Anyone use either of these systems? What kind of tire clearance do the arch brakes have? I am planning on running rigid and would like to use some beefy tires like 2.35 or 2.4's, but am concerned with clearance.
    Thanks for your help,
    -Pedro
    "Speak softly and carry a big stick." T.R. Roosevelt
    aka Willy Vanilly
    Reputation: will8250's Avatar
    Aug 2003
    Hi Pedro. I can't comment on the tire clearance while the wheel is in the frame/fork but I can say that the arch doesn't really allow the brakes to open up all the way, making tire removal annoying (even with 2.1's). They are really nice brakes though in terms of performance.
    If you do decide to go with them, here's a tip for set up: loosen the pads up, set the cable to hold the arms at about the right distance from the rim, and then set the pads. If you try and set the pads with the opposite brake arm "out" (not held in by cable or by hand), the arch changes how the pad hits when you do push the other arm in and your pad adjustment is moot.
    Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction.
    E. F. Schumacher
    sXe
    Reputation: the Inbred's Avatar
    don't bother with the arch rivals. i don't understand the point of them, in all honesty. are they trying to compete with shimano's parallel push, or what?
    go with the 2.0s.
  1. Avid Arch Rival V Brakes?
    By MenaceAllen in forum General Discussion
    Last Post: 02-24-2004, 06:39 AM
  2. new levers for avid mechs?
    By guava in forum Brake Time
    Last Post: 02-22-2004, 12:15 PM
  3. Avid Ultimates w/ Shimano XTR levers...
    By a4racer in forum Brake Time
    Last Post: 02-12-2004, 07:35 AM
  4. Help w/ replacement rotors for Avid Mechs
    By ThornPatch in forum Brake Time
    Last Post: 02-03-2004, 02:23 PM
  5. Replies: 8
    Last Post: 01-20-2004, 03:20 PM
