    only slightly broken
    Reputation: pffft's Avatar
    Avid 160 to 185-what do I need?
    These avid mechanicals are growing on me. What is requried to
    upgrade my front (I am pretty sure the sherman can handle it)
    to 185 (or even 203?!?) Big brakes = good
    patrick
    Feeding your addiction
    Reputation: Ventanarama's Avatar
    Dec 2001
    Quote Originally Posted by pffft
    patrick
    All you need is the larger rotor itself and a new adapter.
    Larry Mettler
    http://www.mtnhighcyclery.com
    GMF
    GMF is offline
    Mmm... Tasty
    Reputation: GMF's Avatar
    Quote Originally Posted by Ventanarama
    This is only tangentially related, but isn't there something about using a rear brake adapter on the front to work with a 185 rotor? I think i remember reading that a while back, but that was also when i was pretty into crack, so i can never tell if i am just making that up, or what...
    On MTBR hiatus :(
    20mm difference front to rear...
    Quote Originally Posted by GMF
    ...so in theory moving a rear 160 adapter to the front should fit a 180mm rotor. It's commonly used in the opposite direction by brakes that use a 160mm front rotor and 140mm rear rotor ? one single-piece caliper design (no adapters) for a clean and light installation.
    However, Patrick's Manitou fork uses 74mm post mounts and requires an appropriate adapter. The 20mm rule only applies to 51mm IS tabs.
  1. Pain in the Hoop - fitting Avid Mechs to Kona forks
    By spangelsaregreat in forum Brake Time
    Last Post: 02-26-2004, 04:35 PM
  2. new levers for avid mechs?
    By guava in forum Brake Time
    Last Post: 02-22-2004, 12:15 PM
  3. Avid Ultimates w/ Shimano XTR levers...
    By a4racer in forum Brake Time
    Last Post: 02-12-2004, 07:35 AM
  4. Help w/ replacement rotors for Avid Mechs
    By ThornPatch in forum Brake Time
    Last Post: 02-03-2004, 02:23 PM
  5. Replies: 8
    Last Post: 01-20-2004, 03:20 PM
