    Reputation: glenzx's Avatar
    Avid 140mm Rear Question
    Wondering if the Ultimate 140mm for the rear is a special caliper - or just a tweaked IS to post mount adaptor and smaller rotor.
    $20 (er - $250!!!) question is can I use a 160mm rotor and 160mm specific IS to post adaptor on the rear and be OK, or is the caliper different - ala Magura's new 185mm Front set-up.
    "It's better to regret something you HAVE done, than something you haven't..." -
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by glenzx
    I suspect the caliper is the same and they are using a 160mm front mount for the rear 140mm rotor. Rear IS tabs are 10mm closer to the axle that the fronts.
    Several other companies use to use the same calipers with built in mounts front and rear by specing a 20mm smaller rear rotor.
    mtbtires.com
    Thanks Shig - sorta what I thought - and cool about the 10mm F/R difference - never knew that!
    Dec 1998
    I have always thought it strange it is not the same front and rear.
    mtbtires.com
