Results 1 to 3 of 3
    Quiet Professional
    Reputation: chef7734's Avatar
    Ashima AiRotorand zee?
    Do these work well together? I like the red on the rotors and plan on purchasing the zee in a month or so. I am a pretty big guy and thats why I am looking at zee with 203mm rotors, but want a bit of bling also.
    Personally? I wouldn't pair an ultra-light rotor and a downhill braking system. The Saint/Zee calipers/pads/rotors all work together in terms of heat control.
    If you aren't going to use them for downhill runs, go nuts (as long as the braking tracks match up) but I think a steel-clad aluminum rotor is pretty blingy already (the Ice Tech rotor). Now that said, I can't seem to find information on the braking track width after a quick google, but I'd imagine you'd be okay.
    Maybe hit up a site that sells anodized bolts (chainring, water bottle boss, etc) to satisfy your desire for bling?
    Quiet Professional
    Re: Ashima AiRotorand zee?
    Thanks. I will go for the shimano rotors with red bolts or screws and red 203mm adaptors. If i change out my hubs i will go red on thode.
    Sent from my Transformer TF101 using Xparent Blue Tapatalk 2
