Results 1 to 6 of 6
    Anyone running Icetech rotors with Hope Evo X2?
    It looks like the brake track of the Icetech rotors is a little short for the X2 pads, but I have gotten away with it on the Cleansweep X rotors. Does anybody have any feedback on this setup?
    Reputation: mazspeed's Avatar
    I have one on the front of my v2. What size rotor?
    I want to run 160 front and rear. Isn't the V2 pad smaller/different? How is it working compared to other rotors that you have run?
    It is a different size, but the shamino disc is fine. The hope rotor hit my forks.
    Is the v2 pad the same height as the X2? I know it is not as wide? Do you see any added performance benefits from the Icetech?
    No real performance advantage at all. v2 and x2 pads are different if that's what you were asking. I personally like the hope rotors, but the ice techs are just as good. You can use them granted they fit. You may need to shim the brake with an extra washer if the disk is to tall.
  1. Replies: 5
    Last Post: 04-16-2014, 04:52 PM
  2. IceTech rotors on non-IceTech calipers?
    By Huggi in forum Brake Time
    Last Post: 07-28-2012, 03:02 PM
  3. IceTech Rotors with Non-IceTech Calipers/Pads?
    By in the trees in forum Brake Time
    Last Post: 06-13-2012, 04:13 PM
  4. Hope Saw 203mm Floating Rotors / Hope Mono M4
    By Deer_Dodger in forum Brake Time
    Last Post: 05-16-2012, 05:34 PM
  5. Anybody running Hope X2's with RT76 rotors?
    By eric in forum Brake Time
    Last Post: 12-06-2011, 11:19 AM
