Results 1 to 2 of 2
    Reputation: chewbacca's Avatar
    Anyone run v brakes with 3.0" tires?
    Anyone successfully run v brakes with 3.0 dh tires? looking at a new project and won't have disc options...
    thanks
    bryan
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by chewbacca
    thanks
    bryan
    It could work if the brake bosses are mounted on the high side of the range. Clearance over the top of the tire is going to be the issue. You might actually have better luck using Paul Retro Cantilevers with an extra wide transverse cable carrier.
    mtbtires.com
  1. What tires do you run at Northstar?
    By Squizzle in forum Downhill - Freeride
    Last Post: 03-29-2004, 05:29 PM
  2. Ahoy! V-brake holdouts!
    By Padre in forum Singlespeed
    Last Post: 03-23-2004, 10:06 AM
  3. Why run two different size tires?
    By 2big2ride in forum Singlespeed
    Last Post: 03-06-2004, 11:31 AM
  4. Replies: 5
    Last Post: 02-27-2004, 08:10 AM
  5. Replies: 4
    Last Post: 02-02-2004, 02:01 PM
