Results 1 to 8 of 8
    Reputation: IRONMAN1518's Avatar
    Anyone out there using a 140mm rear disc?
    Been thinking about trying one, my ridding habits have had to be toned down due to injuries/operations. Found a new 140mm disc,rotor and I have the adapter already.. Bike is an Orbea Oiz, with Crossmax SLR wheels, Shimano centerline discs (both 160mm); BB7 brakes, which work very well for me. It's a great ride for me, a larger rider (225lbs and losing).
    Was just wondering how they have worked for other riders out there. Would really appreciate any input/info, please?
    Thanks lots!
    Training on Hills Builds Character, That's How I Got To Be One!
    If you never overheat your brakes then you should be fine.
    Reputation: Shalom's Avatar
    Nov 2008
    Used them on the back when I was seriously racing. Was good for racing. But could only ever use them racing, as had issues with overheating and brake fade. I need at least a 160 on the back for normal riding.
    rider
    ur 225. dont use 5" rotors.
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    On my FS bike I run 180 up front and 140 on the back and it was the best upgrade I have done to the bike. A 160 on the rear was way to easy to lock up and the 140 is just right ... I can lock it up if I need to, but it is the most responsive drag brake set up I have ever used. I have never had brake fade with the 140 on the back and i am just over 200 lbs. Most of the stopping power is in the front brake anyway so you should be fine with a 140 on the back.
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Reputation: ktm520's Avatar
    What Zoke2 said. Same setup on a hardtail 29er.
    Reputation: Mr_Clean's Avatar
    Oct 2010
    My 26" 4 inch travel FS is setup with 140/160. I ride XC, works great for me.
    Ran a 140mm XTR rotor on my hardtail. It worked fine, but it wore much quicker than 160 I had previously fitted. I've got 160mm F/R now because of my frame. Can't offer much of a comparison because I upgraded my brakes at the same time.
    For the record, I weigh 150, so my reply probably isn't very relevant
    Jamo
    BMC TE01 2011- RS SID Race, ZTR Olympics, X.7/X.9/X.0, 3T
  1. Is 140mm rear disc possible?
    By Gringo in forum Turner
    Last Post: 01-26-2011, 07:10 PM
  2. XT disc converted to 140mm rear + avid adapter
    By bdundee in forum Brake Time
    Last Post: 09-19-2009, 08:05 PM
  3. Anybody run a 140mm rear disc brake?
    By Rb in forum Urban/DJ/Park
    Last Post: 01-05-2008, 07:29 PM
  4. BB7 140mm rear disc
    By equinox in forum Brake Time
    Last Post: 11-08-2007, 08:09 PM
  5. 140mm rear disc rotor?
    By top_ring in forum Brake Time
    Last Post: 02-17-2004, 06:36 PM
