Results 1 to 20 of 20
    11 is one louder than 10
    Reputation: Green Giant's Avatar
    Anyone figure out how to use a 180 rotor with Hayes?
    Just wondering if anyone has figured out an adapter, or used an adapter from another MFG to run a 7inch rotor up front with hayes brakes. thanks.
    "The thing is, Bob, it's not that I'm lazy, it's that I just don't care."
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    I dunno. Would the Magura adaptor work?
    I have one that converts the rear from 160 to 180 so maybe it would work up front. If you can find out quickly then I'll mail it to you to try out since I'm not currently using it.
    Let me know quicky cause i'm in mega-pack mode.
    Do It Yourself
    Reputation: Homebrew's Avatar
    Quote Originally Posted by Green Giant
    The Magura might work although I think the adapter for the Louise FR bumps it up from 180 to 210 for a 30mm jump. You could contact Jimi to be sure.
    This one would definitely work though...
    http://www.a2zcomponents.com/ada.htm
    Long Live Long Rides
    If you have an IS mount front fork then use a rear adapter IS to Hayes adapter on the front- it will work. Also I was able to use the Avid cup and cone washers to make alignment of the caliper easier.
    Do It Yourself
    Quote Originally Posted by VT no 1 2 or 3
    I forgot the Hayes already has an IS adapter so that would be 2 adapters with what I was looking at. You are right. Using a rear 203 IS adapter on the front is easier.
    so what I'm hearing is...
    take the 8 inch adapter for the rear and run it up front, and the 7 inch rotor should work without a problem? or do any other mods/spacing/grinding issues need to be done.
    thanks - GG
    take the 8 inch adapter for the rear and run it up front, and the 7 inch ..
    thanks - GG
    You don't use the 8" rear adapter, you use a 6" rear adapter on the front and then a Avid 185mm rotor (about 7.25") will work. You may also have to use the washer system from the Avids to get the caliper to align correctly.
    thanks
    I may just give that a try this week or next. My fear was the adapter running things too high or low, but it sounds like it may just be a few spacers in either direction. Worth a shot I suppose.
    Do It Yourself
    DOH! Sorry I was confused again. I know the same adapter will give you a 20mm difference from front to rear but brainfarted as to which one is smaller. Magura and I'm sure others make a 180mmx2mm rotor so you don't have to use the Avid 185.
    actually 185 wouldn't be bad
    easier and cheaper to find a 185 rotor than a 180.
    "El Whatever"
    Reputation: Warp's Avatar
    Yup...
    Use the adapters and rotors for an Avíd 185mm. Both Hayez and Avíd calipers are designed to fit directly to a Manitou post mount (well, the Avíd uses the spherical washers, not the Hayez). So, any adaptor for the Avíd will work for the Hayez.
    Even Avíd recommends some Hayez adapters they do not manufacture....
    Check my Site
    Reputation: arlopex's Avatar
    rear adapter is 74mm???
    Just wondering ...is the rear adapter for hayes 6" is 74mm , isn't it??..will tit fit to 51mm front IS of fork??? or with anoher adapter??/ correct me if i'm wrong... peace!!!
    *Disclaimer: Arlopex shall not be liable for the content or any errors or omissions in the information provided in the Comments section, and conclusions drawn from such information are the responsibility of the user.
    "El Whatever"
    Quote Originally Posted by arlopex
    Let's break it down...
    The caliper barenaked is 74mm PM. You need ONE adapter to fit the caliper to the 51mm IS rear mount. The adapter has 74mm PM on one side and 51mm IS on the other.
    NOTE ... the front and rear adapters are different (even when they both fit a 74mm PM to 51mm IS)
    Check my Site
    it works but...
    I hope you can help me VT no 1 2 or 3, I followed your suggestion using the rear hayes adapter for 6" and it works fine perfectly...i used a 180mm 2mm thick aztec rotor...they are exactly fits with no washer at all...i just cant fugure.. out theres friction between the pad and rotor maybe because the 2mm is too thick or do i just need to adjust the caliper alighment ...what did you do or you dont have this problem with avid? i'll try again tonight to align it to the claiper i hope i'll work...o well....your suggestion are welcome. thanks
    Reputation: shiggy's Avatar
    Dec 1998
    EASY!...for a 185 mm rotor (not 180 mm, not "7 inch"). Most - if not all - Hayes calipers are 74 mm post mount and use a bolt-on mount for IS.
    Just buy an Avid 185 mm mount and the 185 mm rotor of your choice and bolt them on.
    DONE!
    mtbtires.com
    Wink 180mm is 7.092 inches....
    Quote Originally Posted by shiggy©®™
    DONE!
    180mm is 7.092 inches....185mm is 7.289..nway i already bought the 180mm and rear hayes..adapter...it fits well....i just cant figure out how to take away the dragging or rubbing of rotor and the pad....should i adjust the pad...but its self adjusting right? is there a technic to properly align the rotor to the caliper? i tried the hayes instruction to squeeze it then torque but still theres little dragging...if i leave it like that, will it affect the performance of the brake? or any affect on my riding? or do i need to break-in the rotor with the pad so it will fit properly..thanks for the suggestion.
    Have you tried pushing the pistions back into the caliper to allow them to adjust to the thicker rotor? Also I don't center the caliper over the rotor- I center it over the warps in the rotor. I do this by using automotive feeler gauges, spining the wheel till I find the most warped section and move the wheel so the most warped section is in the caliper, put about a .005 to .010 feeler gauge between the rotor and caliper, sqeeze the brake lever to hold everything in place and torque down the caliper mounting bolts. I may have to repeat the process several times using different thickness of feeler gauge till I get things right. If you have put in new pads you may not beable to eliminate the rubbing till the pads wear a bit to get enough clearance.
    I bike; therefore, I work
    I'm thinking of doing that last night but i'm tired already... i'll try it tonight push the piston...then i'll you know if evrything works fine...thanks.
    not so super...
    Reputation: SSINGA's Avatar
    Avid, Hayes and Hope...
    Quote Originally Posted by shiggy???
    DONE!
    Shiggy is correct - Use the Avid Adaptors. I run a 203mm front and 185mm rear using Hayes brakes, Avid Mounts and Hope Rotors.
    Avid Adaptors are cheaper than the Hayes also!
    Cool-blue Rhythm I got it...
    VT no 1 2 I got it...I pushed the piston a little...and now its ok...i already test ride the bike last saturday...and its awesome....thanks for the suggestion....
    shiggy and ssinga..thanks also for the suggestion but i'm ok with the 180mm maybe next time...BTW i can only run 185mm max on my fork not to void the warranty. maybe the rear I'll use the 185mm avid. adapter ..thanks ..peace go ride
  1. Hayes Hydraulic Rub...
    By philipshaw in forum Brake Time
    Last Post: 06-17-2004, 04:52 AM
  2. Romic or Swinger 4way coil for 5 Spot
    By Alpenglow in forum Turner
    Last Post: 05-19-2004, 06:20 PM
  3. Hayes MX1 vs. MX2?
    By czardonic in forum Brake Time
    Last Post: 03-26-2004, 02:30 PM
  4. Hayes or Avid for the Fuel?
    By Spaz in forum Trek
    Last Post: 02-23-2004, 05:13 PM
  5. Hayes or Avid for an '01 Fuel 90? (x-post)
    By Spaz in forum Brake Time
    Last Post: 02-10-2004, 08:01 PM
