Results 1 to 7 of 7
    Any specific procedure to refill empty hydraulic system?
    I tore down my brake levers and also emptied out my lines and calipers to clean them. I'm waiting on new replacement parts before I rebuild the system.
    I wanted to know, is there a good way to fill the system with DOT fluid so air and bleeding will be at a minimum?
    It seems the basic bleeding process won't do for refilling an empty system. I'm thinking refill from the caliper, up the lines, until it over flows at the lever. Then do a couple of bleeds until it feels right.
    Any better ideas would be appreciated.
    Before I sold my Shimano M665 brakes (mineral oil) I emptied out one of the sides. When I re-added fluid I just did a standard bleed (adding in reservoir, pumping lever, etc.). I think I used more fluid than I could have, but I was really trying to be thorough. The lever was nice and firm.
    Wouldn't spilling dot fluid out of the lever potentially damage whatever it gets on?
    Reputation: Shalom's Avatar
    Nov 2008
    Depends on the brakes you have. They are all different when it comes to bleeding. Read the instructions for the brakes you have and then do a google search to see what other people recommend. Might also pay to have a chat to your local mechanic to see if he has any tips.
    Quote Originally Posted by bing! View Post
    ...I'm thinking refill from the caliper, up the lines, until it over flows at the lever. Then do a couple of bleeds until it feels right...
    Sounds about right for your Juicy's.
    Nuts
    Reputation: bdundee's Avatar
    I filled a set of XT's and went from the caliper up, just made sense that air would rise easier. I didn't even have to bleed the front one. Of coarse that was mineral oil so all I did was put a catch pan below the lever and let it flow out. Not sure how Avids are but maybe you could install the bleed fitting on the master cylinder and a hose and let the extra fluid flow into something.
    And I love beer!!
    Quote Originally Posted by jsilva View Post
    DOT fluid isn't that bad. As long as you wipe down the over flow and spray the part with alcohol within 5 minutes, its ok.
    Just follow Avid's directions and collect the DOT fluid in the lever syringe.
  1. Replies: 26
    Last Post: 06-22-2012, 06:53 AM
  2. Avid Elixir CR hydraulic bleeding procedure?....
    By dirtrider7 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-05-2011, 01:27 PM
  3. Stan's refill Q
    By gfs69 in forum Wheels and Tires
    Last Post: 11-23-2009, 07:46 AM
  4. Empty System Fill and Bleed
    By AlexJK in forum Brake Time
    Last Post: 10-14-2009, 07:09 PM
  5. Haraka Hydraulic Disc Brake System
    By bragaman in forum Brake Time
    Last Post: 03-20-2008, 03:39 PM
