Results 1 to 10 of 10
    Reputation: 1reddawg's Avatar
    Another Pad seperates from backing
    I am soooo getting tired of this happening I have a 07 Stumpy w/Avid Juicy 7 brakes on it,and just got another new set of pads in Nov.to replace the pads that seperated just like this pair did,and another pair before those Is this a common problem with these pads,or am i just to dam hard on these brakes..I have only had the bike a little over a year and this is the 4th time i have had to replace these pads cause of the same problem Any advise would be greatly appreciated..
    Reddawg
    bi-winning
    Reputation: rkj__'s Avatar
    Wow, i have never actually heard of that happening. My avid pads have been fine.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Are you using the OE pads? I've seen the material separate with cheaper aftermarket offerings... Are you using any sort of cleaner on the pads?
    Perhaps you should try another brand... EBC, Koolstop, or Galfer.
    Yes, they are OE pads.No cleaner on the pads.,
    Reputation: bigfish's Avatar
    I had had the same exact thing happen to my avids twice, once while riding...lucky it was not on a big hill.
    Just do it, Faster, Better, Lighter.
    bikekitchen.blogspot.com
    Single Minded
    Meh.
    I'd call up SRAM and let them know this is happening. They might flow you some free pads too.
    If it were one set... I'd say bum pads... but maybe you're overheating the brakes?
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    I've had two stock sets, and now I'm running Koolstop pads. Have never had this happen to me....
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    I've seen it happen from overheating the stock pads.
    May contain nuts
    Reputation: Haggis's Avatar
    Quote Originally Posted by 1reddawg
    Organic or sintered? My stock sintered last an absurdly long length of time. I'm thinking of changing the front pads after 2 years just because...
    Quote Originally Posted by Schmucker
    I doubt it is from the pads overheating,this last time it happened,i was only into my ride about 1 mile and that was all single track with hardly any brake usage at all till this small 10 MPH downhill right, left, combo . Thanks for the replys..
    Reddawg
