Results 1 to 6 of 6
    MTBR Mafia
    Reputation: cdub's Avatar
    Feb 2005
    Another Juicy 7 Q
    could not find any info on my current problem. my front rotor can rotate maybe an eight of an inch in either direction so it feels like something is wrong. how can i tighten the rotor soit doesnt get any forward, backward play?
    Try tightening your rotor bolts. They may be loose and if used, sheer off the disc mounts on the hub
    Reputation: Festusjrf's Avatar
    check your bolts
    check your rotor bolts make sure they did not bottom out before the rotor was tight.
    http://www.caddesignwork.com/ where CAD Design and drafting happens.
    MTBR Mafia
    Feb 2005
    sory but i am new to the disc break craze. what are the rotor bolts and how would i bottom them out. if some one can please tell me in dumb mans terms that would be greatly appreciated.
    Reputation: mtbykr's Avatar
    Your bolts
    your rotor bolts are the six screws that hold your rotor onto your hub. take the wheel off and see how it's connected. bottoming out them means: were the bolts too long so that they hit the hub (or something) that prevented them from seating completely. make sure there is still room under the end of the bolt as well as making sure they are tight
    hope that helps
    The nine most terrifying words in the English language are, 'I'm from the government and I'm here to help.' --Ronald Reagan
    yep thats it
    sorry for the terms I used I could have made it easier to understand. On some hubs it can be a big Problem if the screws hit bottom before they clamp the rotor it can snap the hub. A good way to check is to screw the bolts in with out the rotor ( do not tighten) and then see if the rotor fits between the head of the screw and hub.
  1. Goodridge lines on Juicy 7
    By Ventanarama in forum Brake Time
    Last Post: 05-04-2005, 09:26 PM
  2. Yet another stuck Juicy 7 Piston-need help
    By string in forum Brake Time
    Last Post: 12-23-2004, 08:22 PM
  3. Brake Weights: Juicy 7, BB7, XT hydros?
    By staind in forum Brake Time
    Last Post: 12-14-2004, 03:01 PM
  4. diff. between Juicy 7 and Juicy 5
    By danK in forum Brake Time
    Last Post: 10-07-2004, 08:51 PM
  5. Avid Juicy 7 n00b questions.
    By martynda in forum Brake Time
    Last Post: 09-22-2004, 07:52 AM
