Results 1 to 3 of 3
    Dream it, Do it.
    Reputation: Spectre's Avatar
    Amount of expansion for Mineral Oil vs Hydraulic Fluid
    How much does mineral oil expand vs hydraulic fluid? I have XT 775 discs and had a problem with dragging brake pads when the brakes got hot. I seem to have mostly fixed the problem by bleeding out some brake fluid. Will mineral oil expand enough to cause pads to drag?
    Reputation: canonshooter's Avatar
    I also have XT 775 discs...I changed from Shimano Mineral Oil to Pentosin... HUGE improvement in stopping power.
    I had the same issue with my XT's rubbing a bit initially, after switch they are great. No rub. Whether or not it is related to the fluid I dont know.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Yes, but its only temporary and is much friendlier than corrosive DoT fluid. My XTR M965 did it - but when I upgraded to lighter, Magura Marta SL....the issue was non-existant. Magura rules!
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
