Is there anything that works better than zip ties for attaching brake cables to the guides?
They work fine and all, I just don't really like the look of the big end (that the tie goes through) on the top tube of my jabber build up....
I know, I'm being really anal, but with a screwed up arm, I can't ride so I have lots of time to stare at my current build and think about these things...
I use small zip ties, and cut the remaining plastic as close as possible with a flat cut tool. It doesn't leave a tip or anything, just a perfect cut on the little "cube".
I too went back to zip ties after seeing my mechanical brake line move within the guide. Maybe it's my head, but my brakes feel better and I see no movement in the lines what so ever. I use a serrated utility knife blade and I get clean cuts. Here's what i'm talking about:
Oh, I think a wire cutter makes a clean enough cut
The difference between a regular wire cutter and what I use is that mine leaves a flat cut, and the regular one doesn't.
Look at this:
With bevel (standard)
Cutting edges with a bevel are suitable for all wire classes, depending on the nipper design and capacity.
With small bevel (semi flush)
Cutting edges with a small bevel are suitable for all wire classes apart from piano wire, depending on the nipper design.
<--This is what I use Without bevel (full flush)
Cutting edges without a bevel are only suitable for soft materials, i.e. lead and plastics.
