Results 1 to 3 of 3
    May contain nuts
    Reputation: Haggis's Avatar
    Alligator Universal Bleeding kit better than Hayes?
    Quote Originally Posted by Haggis
    I have a Hayes bleed kit that cost about $15, and even at that price it's a rip.
    You can DIY (do it yourself) for much less.
    Big syringe: $1 at vet or hardware store.
    Tubing: 50 cents
    DOT fluid: $2 for a lifetime worth as opposed to Hayes charging $$$$$ for so little.
    I gave my Hayes kit away. The stupid squeeze bottles are so pathetic compared to a syringe you can push and pull fluid and air with.
    shut up and pedal
    All you really need is the syringe. The metal adapters appear to to replace the bleed screw with a fitting for the hose. If I worked in a bike shop it would be money well spent. All you need to do to seal the bleeder is, wrap some teflon tape on the threads. I use the hayes bottle as a catch bucket, works good for that and nothing else.
  1. Hayes Question
    By Quattro in forum Brake Time
    Last Post: 07-07-2004, 08:37 AM
  2. Hayes HFX-9 lever-assembly problems
    By SDGrinder in forum Brake Time
    Last Post: 06-02-2004, 01:41 PM
  3. Romic or Swinger 4way coil for 5 Spot
    By Alpenglow in forum Turner
    Last Post: 05-19-2004, 06:20 PM
  4. Spring in Hayes bleed kit???
    By 80z28s6 in forum Brake Time
    Last Post: 04-22-2004, 09:27 PM
  5. Anyone make a bleeder kit for Hayes brakes?
    By Locoman in forum Brake Time
    Last Post: 03-18-2004, 11:05 AM
