Results 1 to 6 of 6
    ♥ ς╥33
    Reputation: longcat's Avatar
    are all rotors the same thickness?
    Are they? If not what is the spann?
    Quote Originally Posted by Curmy
    Carbon is a fad.
    Quote Originally Posted by robicycle
    Just lube your ass with asscream and ride for how long you want.
    Reputation: vk45de's Avatar
    close but not the same. around 2mm thick
    From what I have measured and seen listed. It goes from 2.1 mm (a magura SL drilled I measured) to around 1.7. for a Formula R1 (2 piece)
    The others I have seen and/or measured seem to fall somewhere in between.
    Keep something in mind, your brakes were designed to use a certain width rotor. If you use another brand, you may have some adjustments to do.
    Lead by my Lefty............... right down the trail, no brakes.
    My 160mm Alligator windcutters I just installed are thinner than the Avid clean sweeps that came on my bike. I had to go in about 2 clicks on both pad adjusters front and rear and the caliper needed a slight adjustment.
    ♥ ς╥33
    I would like to run some magura rotors with formula calipers, I hope it works out good.
    Carbon is a fad.
    make sure the brake tract on the rotor is wider than the caliper's pads.
