Results 1 to 10 of 10
    Off the saddle
    Reputation: jizzim's Avatar
    Aligning caliper to disc (Shimano M988)
    Hey guys, is there a trick to snugging up the caliper bolts on the M988? I have it perfectly lined up but when I apply a bit more torque on the bolts the caliper shifts with the turn of the bolt. I can't seem to hold the caliper in place while tightening it up. I think the manual called for 4 inch pounds and that's damn near finger tight if I'm not mistaken. I wish I had a small torque wrench but I don't. I think I'm more than finger tight right now. This is for the front caliper.
    Is something like blue thread locker advisable? I'd hate to have the caliper shift on me during a good ride.
    Edit: I just did a quick test run around the block with hard front braking and now I'm getting a tiny bit of disc rub.
    Thanks.
    Edit edit: I fixed the problem. I threw on the OEM bolts with the washers and it had enough gripping power to keep the caliper from moving. I switched them out initially to Ti bolts just because. I'll stick to the OEM bolts for now unless I can find thin washers for the Ti bolts.
    Dave's not here.
    Reputation: MiWolverine's Avatar
    According to the tech docs for the M985 (shouldn't be any different for yours), the torque should be 6 - 8 Nm {53 - 69 in. lbs.}. You may have to try and hold the caliper in place while slightly torquing the bolts down to ensure the caliper doesn't shift. Just out of curiosity, do your bolts have washers on them?
    Tech doc
    I am the world champion of bad luck, but I tell you what, I'm undefeated!
    Off the saddle
    I stand corrected. Misread the damn instructions on the torque spec. Yep, the factory bolts did have the washers on them with dried blue thread locker. I was just trying to be one of the cool kids and use the Ti bolts.
    With the factory bolts on I SLOWLY torqued each bolt alternating between the two and getting a good grip on the caliper. I think all is well now.
    In the future, oiling the washer before tightening the bolt will help keep it from walking the adapter/caliper off where you want it.
    Reputation: CRchris1996's Avatar
    loose the bolts press the lever keep it tight, tight the bolts you are done
    For me I have had to use a rubber band to hold the brake lever tight on the disc, and then I tighten each bolt a little at a time until snug and then hold the caliper to keep it from walking for the final tightening.
    Quote Originally Posted by firebike7 View Post
    you explain it better with this method is almost imposible that it gets in the wrong position the only way is that the rotor is bend or a mistake by tightening the bolts
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Quote Originally Posted by CRchris1996 View Post
    No. Not the proper way to do it. Yes, I'm aware its what Avid recommends for their CPS system and it does not properly set up the caliper. Watch the videos on Hope's site on how to center a caliper and then how to centralize pistons. Its a two step process to do it right and get the most power out of your brakes.
    I use spark plug feeler gauges to center the caliper over the rotor and once I get the gap equal on both sides (without the pads in), I leave the feeler gauge in there while I tighten the bolts. Flawless setup every time.
    007 is offline
    b a n n e d
    Jun 2005
    Or you have a sticky piston, or a slow piston, or a misaligned/stuck piston . . . worse if you have more than 2-POT brakes.
    Off the saddle
    I tried this too but still kept on getting light rubbing.
  1. Shimano XTR M988 brakes XT Caliper
    By Tyson2007 in forum All Mountain
    Last Post: 08-15-2013, 01:44 AM
  2. Shimano XT M785 disc caliper broken
    By rave81 in forum 29er Components
    Last Post: 04-17-2013, 12:51 AM
  3. Replies: 1
    Last Post: 01-02-2013, 03:15 PM
  4. Shimano M775 caliper with M988 lever
    By gnarly in forum Brake Time
    Last Post: 12-02-2012, 09:17 AM
  5. Shimano XTR Trail BR-M988 Disc Brake $199
    By Singletrack Pig in forum Where are the Best Deals?
    Last Post: 03-16-2011, 08:39 AM
