    Air bubbles in resevoir
    I'm new to bleeding brakes, but after bleeding my martas the front is fine, but on the rear brake when I pump the lever (with the cover off) bubbles keep floating out into the resevoir.
    This is after several re-bleeds. I can't find leaks anywhere. Are there seals that can go bad? Or what?
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Have you checked out the Magura site??
    http://www.magura.com/english/frameset/frameset.htm
    Formotion Products
    http://www.formot
    Thanks Dogonfr. I found a forum on the Magura site that talked about leaks from seals at the lever. Nothing about it leading to air bubbles, but I guess it make sense that a leak would let air in. Now to see if I can fix it.
    Jan 2005
    I just noticed they use Flash so there is no link to the manual. Go to Catalogue Download then fill in the information, year, product then model.
    Marta workshop manual 2008 ENGLISH
    Year: 2008| English | 870 KB
    Service Links
    Warranty / Registration
    Support Forum
    Catalogue Download
    MAGURA On Tour
    Download
    FAQ
    Product Recalls
    Links
    Here we put the technical documentation of any MAGURA product of the last years at your disposal. If ever your technical documentation went astray there is no need to worry then.
    The technical documentation including spare parts lists of all our stuff can be easily downloaded from here in a convenient A4 format.
    Please select:
    Formotion Products
    http://www.formot
