Results 1 to 2 of 2
    Jan 2013
    Adjusting my Elixer 3 brakes. (yes another one with issues)
    2013 Trance X1. Front squeals like a pig getting raped. I taulked (ny accent) into thinking that its a safety feature so my friends know where im at.
    My bike was in my hot garage, took it out 2 weeks later. I unloaded it of my rack and as i moved it i noticed the rear brake was locked. Some how in those two weeks, some one broke into my garage and put a lot of oil in the lines under pressure so the piston would prevent the wheel from spinning.
    I did not have anything to crack the bleed screw in the back so I removed one of the pads. I rode that day with just the front brake.
    Ever since that day I cant get good pressure out of the dayum thing. I bled it, LBS bled it, then I bled it again, then another LBS bled it and now Im goign to have to bleed it again cause mine would come out the best.
    What I would do is remove the return spring clip then bleed it with the pads making contact with a shim I used which is almost as thick as the disk. This gave me the feel I wanted where the lever would not toucn my finger on the bars once fully pressed. Not the proper way to bleed it i know but atleast it work better than a regular bleed.
    I had the 2013 anthem X1 and sold it after 3 months (awesome bike). Loved those shimanos on it. LEts see what I do. I know those brakes will be canned.
    The Original Suspect
    Reputation: HitmenOnlyInc's Avatar
    Sorry to hear your issues, Elixers are temperamental to say the least. Good luck!
  1. Avid Elixer 5 issues. Keep or Punt.
    By jackblack in forum Brake Time
    Last Post: 09-30-2012, 11:37 AM
  2. elixer 1 juicy seven
    By bnelson in forum Brake Time
    Last Post: 04-15-2012, 04:30 AM
  3. Anadale Great! Braks bad :-(
    By Shane64 in forum California - Norcal
    Last Post: 01-12-2012, 09:58 PM
  4. Elixer 5 Problem
    By D-Avid in forum Brake Time
    Last Post: 04-28-2011, 12:11 PM
  5. Elixer CR mar pad adjusters
    By iammemares in forum Brake Time
    Last Post: 01-03-2011, 07:13 AM
