    Adjustable bolt on brake v-brake levers??
    What is the little bolt for exactly on v-brake levers/mechanical disc brake levers? Levers are just shimano deore ones...
    Jul 2003
    I am assuming that you are talking about the small 2-2.5mm allen head bolt that is threaded through the pivot knuckle on the lever blade. If that's the case, that is a reach adjustment. Turn it in and it moves the lever blade away from the bar, turn out and the blade moves closer to the bar.
    Good Dirt
    Ah, I should have given a little more info...It's a small bolt, on the inner side of the handle bars, its a philips head bolt with a little spring around the thread...
    Jul 2003
    Ah, same thing! Reach adjustment screw. I forgot Shimano puts the adjustment screw on the front of the brake lever housing above and behind the barrel adjuster. Does the same as the 2.5mm bolt on the lever blade, just a different location.
    Good Dirt
