Results 1 to 33 of 33
    Adaptor for disc brake mouting on forks?
    HI. I am trying to mount a XTR M-965 disc brake on a Manitou Minute fork. If the rider were looking down at the front brake, my XTR caliper's mounting bolts screw on from left to right, perpendicular to the direction of bicycle travel (same as any rear brake, although this is the front brake). The Minute's bolt holes accept these screws in a direction parallel to the direction of bicycle travel. In other words, the fork accepts the brake bolts in a direction 90 degrees from how the brake was designed to mount. What adaptor is available to alleviate this problem? It seems kind of silly to have different methods of mounting calipers on different forks.
    simply me
    Reputation: bostonkiwi's Avatar
    Manitou forks use the 'post mount' system, most other fork manufacturers use IS mounts, the brake set you bought happens to be available in either standard, you have the IS version. Adapters are available from most LBS's to convert but you may also need a larger dia rotor. You are better off swtiching for the correct caliper if the brake is still as new.
    Lightweight Ghost Rider
    Reputation: Knut's Avatar
    What bostonkiwi said - also, the correct caliper is BR-M966.
    Chrome Toaster
    Reputation: Hecubus's Avatar
    You'll need a 74mm post mount to IS converter as well as a 170mm or larger rotor. Its better if you can just get the correct caliper for it.
    Oh Great! How silly for every manufacturer to have their own method of doing things! I don't really feel like buying a new caliper and hose and dealing with the hassle setting it up, so I guess I will just get a different fork! Does Fox use the IS standard?
    If you are using a 6" rotor, try taking the mount off of the caliper. The bolts holding the mount to the caliper should be parallel to the bikes movement. Then try to mount the caliper directly to the fork. I know this works for the Avid Mechanicals and may be worth a try before you go hunting for the right parts and new rotor.
    Brandon.
    Chrome Toaster
    Quote Originally Posted by BrandonAggsMntnBk
    Brandon.
    That won't work because shimano's IS mounts are a fixed machined part of the caliper. Avid and Hayes only make 74mm post mount calipers and use adapters to mount it on IS type forks. The 74mm post mount XTR 966 caliper could be adapted to either post or IS mount the same as the Avid/Hayes but not the IS mount XTR 965.
    Quote Originally Posted by Hecubus
    Thanks for the help. It probably would be silly to run a 203mm rotor up front,and may not be recommended with the XTR caliper anyway. Buying another caliper seems silly, but may be the only option, unless I go with a Fox TALAS instead of the Minute One (I was looking forward to the coil and saving some $). What do you think I can sell a very lightly used front caliper XTR M-965 on Ebay for? Also, what the difference between the XTR and XT 2-piston caliper-I notice the XT is $15 cheaper and 50 grams lighter.
    Chrome Toaster
    Quote Originally Posted by dawgcatching
    The XTR can run 203mm rotors. Shimano is supposed to even be releasing an 8" center lock rotor specifically for the new XTR's. I had to go through the same thing when I switched to a Minute 3. I sold my IS XTR caliper on ebay for $80 and got the post mount version. The new XT caliper is basically the same thing except it weighs a bit more.
    It is an issue with the ISO fork attachment strength.
    Manitou doesn't feel the ISO standard is strong enough. There are brakes that attach to the Manitou style, like Hayes and Avid, so Manitou hasn't yielded to the standard. Lest you think they are being too conservative, you should know that some manufacturers have experienced failures of the ISO tabs, particularly when using larger rotor sizes. For example, Fox limits the rotor size with some of their forks and Specialized actually recalled the front brakes on a Fox fork equipped bike, to replace them with a smaller size.
    Reputation: scottay's Avatar
    part numbers?
    anyone got an adapter for '02 shimano xt calipers to mount to a manitou fork? or a p/n? thanks, scott
    You can check our website for the adapter you need.
    www.discbrakeadapters.com
    thanks
    thats what i need. where are you located? what do you charge for shipping? scott
    If you have to ask...
    Reputation: miles's Avatar
    Manitou has got it right.
    Current motorcycle racing brakes have HUGE rotors, and calipers of mind-boggling strength. To allow this level of force on the leg, the manufacturers are going with what are called "Radial Mount" calipers. They are (yep, you guessed it) pretty much just like the post-mount design that Manitou forks have.
    The idea is that traditional-mount (or IS in Bicycles) calipers create strong shear and torsional force against the leg, but Manitou/Radial mount calipers distribute force evenly into a larger, thicker casting.
    miles
    simply me
    The downside to the postmount system is if you cross thread or other wise screw up the mount your lowers are toast.
    Quote Originally Posted by miles
    miles
    helicoil
    could fix that.
    It sounds like replacing the caliper will be the better option for me, over getting the adapter and new rotor. If I can get $80 for the used caliper and get a new one here for under $100, then it is the cheaper option as well. Does the XTR M-966 caliper (post-mount compatible) have adjustment for rotors or forks/hubs slightly out of spec, like the Avid's do? this is a concern for me-I was working on a Hayes HFX-9 post-mount version today (on a Manitou Black) and adjustment range was very narrow.
    Why silly to run a 203?
    and how about the Saint caliper, hows that differ from xt/xtr? Will a Minute handle that size rotor? And will my '02 xt brake lever and hoses work on '04 calipers? Its a banjo type fitting on the caliper. Thanks, scott.
    Quote Originally Posted by scottay
    Our website automatically calculates shipping based on weight, your location and the method of shipping you prefer. You can e-mail me at sales@discbrakeadapters.com with your info and I can give you an estimate. Thanks.
    miles
    Strange my truck has "ISO style" mounts and stops a lot more weight, my dads dump truck has disc brakes and they are mounted the same way, between the truck and trailer you are looking at almost 200,000lbs.
    Pat T.
    New question here. Where did you find one?
    Like you, Just got a Minute and already have xtr discs. Where did you get the caliper if thats the way you went? How did it work out? TIA, Rob
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    I went the adapter and 203 disk way, I'm running a Manitou Black Super and it's approved my Manitou to run 203 rotors on it.
    I'm using the "old" M755 XT Hydros and couldn't find a post mount version, the only option that I was able to find was to upgrade to the new XT/XTR caliper and that was a more expensive solution.
    Where to get the parts? Your only option is your friendly neighborhood LBS, Shimano doesn't allow e-tailers to sell parts on line. Lucky for me the shipping guy from the e-tailer that I got my parts from shipped them by mistake. E-tailers are only allowed to sell complete products. E-tailers like Jenson and others sell other brand rotors that come in the 203 size.
    ok Postmount versus IS mount
    When the IS standard was born Manitou was the only person who objected ( actually the main person, who objected is no longer at Manitou ) . They found an friend in the Dia Compe disc brake, and later with Hayes . Hayes than came out wwith their own stuff and delivered what their main customer at the time wanted ( that was Trek )
    Rockshox was instrumental in testing and pushing for the IS ( together with all Disc brake manufacturers ) The involvement from Rockshox was in my opinion the ONLY reason for the postmount (For their DH forks Manitou came up with all together 3 different IS look alike mounting points at the time ???remember the Xvert and Xvert TI )
    Infinite strength testing in various labs and universities all over the world proved that IS is the way to go. But Manitou had a big customer with Trek and Hayes had a big customer with Trek, both together had a nice portion of the market locked in.
    Not at all a bad MARKETING decision. ( I am NOT flaming Manitou in any way, I like the guys, and again they made the correct for them decision at the time )
    In other words, its not all black and white , and the postmount had to be changed from 68 to the current 72 mm in order to faciliate larger rotors and to spread the load better.
    Now if you take into cnsideration that every brake manufacturer has to make molds or bracketery to mount on either one, and the cost involved , the looser is the consumer, as he usually picks up the extra cost involved to offer both systems.
    But its not all that bad really. After all we have to deal with 2 different systems and not 20 different anymore. Check out the Motorcycle Industry, they all have different hubs, different nounting points ( mostly like IS ) every different Motorcuycle has different rear sprocket and front sprocket mountings and so forth ... Much better in the bike biz.
    Brakemeister
    Flyin Canine
    Reputation: shanedawg's Avatar
    Quote Originally Posted by Pat T.
    Pat makes some good points here. It seems to me that the IS mounts place the loads on the cross section of the bolts and the metal surrounding the hole where the bolt goes through the fork leg. The post or radial style places the pulling forces on the THREADS of the lower bolt. The threads are the weakest part of the bolt and I can't understand why anyone would do this.
    Keep in mind that just because the "motorcycle" industry does something doesn't mean it's smart. I have a Kawasaki Ninja ZX-6R so I am into that stuff and I'l tell you this much. The engineers and marketing people in the motorcycle biz absolutely have to make changes to their bikes every year to catch the customers eye and make them buy new stuff. The competition among sportbikes is so tough that they seem to sometimes make changes to just grab the spotlight. Not all of these changes make a noticeable improvement but the customers can't tell the difference because 99% of them don't push the bikes to the limit. I don't see how the changing of the bolt placement is going to change the torsional forces exerted on the fork leg either. That would seem to be caused by the inboard location of the caliper in relationship to the center line of the fork leg. Changing the bolts does not change this relationship.
    Another thing. I have heard that the 185mm limits on most forks are not about the IS bolts or mounts breaking but the issue of force exerted on the QR axle and making sure that the QR axle doesn't come out of the dropout. That's why the 200mm rotors are mostly approved for 20mm axle model forks.
    Reputation: E-man's Avatar
    I've got a Shimano 74mm post-mount to IS adapter and a 170mm Shimano rotor for sale. Send me an e-mail or PM me if interested.
    Oakley - High Definition Optics
    Thread is a bit old, but I happen to have the opposite problem. I am harnessed with a brand new XTR M-966 and a Fox TALAS. I happen to have a post adaptor, but would prefer the IS M 965.
    I would love to straight across swap. Caliper body for caliper body.
    soviet pride
    Reputation: ilikepinkbikes's Avatar
    Dec 2004
    ok if anyone ever sees this post anymore, can u answer this? is there an adaptor to which i can mount a 203mm avid rotor to manitou black fork. And please dont search for it on pricepoint cause i already bought that only to be dissapointed because my 203mm brake already came with that adapter which happens not to work. So if there is an adapter whcih i can use to mount an 203mm avid mech brake, can someone please show me cause im getting really pissed at my brakes
    Quote Originally Posted by ilikepinkbikes
    This is from Avid:
    Avid’s larger rotor sizes (185mm and 203mm) are compatible with Manitou forks but require an additional caliper mounting bracket. Avid offers these brackets and they are available through your local bike shop.
    An Avid Disc Brake with a 203mm rotor will fit the Dorado, but requires a specific bracket from Manitou.Note: 185mm and 203mm rotors require a caliper mounting bracket that is specific to Avid’s 2002 and later calipers.2001 calipers are not compatible with 185mm and 203mm rotors on Manitou Forks.
    Note: Fork manufacturers often discourage the use of anything larger than a 185mm rotor on a standard quick-release.
    Anyways, I found some adpaters on the webcyclery site, they are $10. But it looks like if your brakes are 2001's you can't run the 203mm rotors.
    Pat T.
    soviet pride
    Dec 2004
    i dont have the 2001 versions so i think im good on that part but if u can poibt me out some adaptors, that would be greatly appreciated.
    thanks , Andre
    thanks , Andre
    Well I found some at webcyclery.com:
    http://www.webcyclery.com/product.ph...7&cat=0&page=1
    Pat T.
    ballbuster
    Reputation: pimpbot's Avatar
    Sounds to me...
    like buying a new fork is sillier than a new caliper. Heck, you can prolly find somebody to trade with.
    A wheelist
    Reputation: Mike T.'s Avatar
    Every manufacturer doesn't have their own standard. There are just two basic ones - because Manitou wouldn't accept the IS standard when it was proposed as THE standard. For that reason alone I'd never buy a Manitou fork.
    Hayes were awkward too and wanted to use their rear brake mount instead of the IS. I'm sure they suffered because of their ideals. Not many (any?) other brake makers ever embraced their rear mount.
    As you have now found, front calipers are available in the two mounts from most makers. This info is in our FAQ at the top of the page.
    Mike T. (mcm # 717 & FOG)
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilders with information and motivation.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Mike T.
    And just as it looked like we had a consensus with the rotor mount standard Shimano introduces Centerlock and there are even two different versions of that!
    mtbtires.com
  1. Replies: 13
    Last Post: 01-30-2010, 11:53 PM
  2. Using rear brake too much?
    By keen in forum Brake Time
    Last Post: 03-22-2004, 12:27 PM
  3. Magura Marta brake drag question
    By dgangi in forum Brake Time
    Last Post: 03-01-2004, 09:42 AM
  4. 5 spot : spring ? forks ?
    By tne in forum Turner
    Last Post: 02-27-2004, 07:49 AM
  5. how important is the rear brake??
    By jake in forum Downhill - Freeride
    Last Post: 02-21-2004, 11:07 PM
