Results 1 to 7 of 7
    Reputation: SeaBass_'s Avatar
    Which Adapter for XT M755 Front Caliper?
    So my new Niner fork is Post Mount and of course my caliper is IS mount. Is there an adapter I can obtain that would allow me to keep my 160mm rotor?
    B A N N E D
    No 160mm adapter will fit your brake caliper it's far too big, only certain brake calipers will fit the type of adapter you're thinking of. You'll either have to get a bigger rotor with a suitable adapter or get a new brake if you want to stick to 160mm.
    Thanks Cobba.
    B A N N E D
    Thanks again. Needed a reason to go with 180 for my Clyde ass anyway.
    If you don't want to go all the way up to 180mm, Shimano also made a post to IS mount adaptor for 170mm rotors. Unfortunately it's pretty darn expensive for some odd reason, like 5 times more than a 180mm adaptor. Mine came with my kit when I bought my XT discs around 10 years ago.
    It would've been cheaper to purchase a post mount caliper than to go the 170mm route!
