Results 1 to 5 of 5
    Reputation: steve47co1's Avatar
    May 2005
    Which adapter to use with Shimano caliper and Avid rotor?
    I am running Shimano Saint calipers with Avid 6 bolt 203 rotors and it has been working well. I just decided to go smaller - from 203 to 185 and when I got the Avid front brake adapter for the G3 rotor I had to use 2 washers to make the pad contact work. I am not happy with that type of setup.
    This is a 74mm post mount setup on a Lyrik fork. Any ideas on which adapter would work in this situation without changing my caliper or rotor brands?
    PS The rear brake/adapter/caliper went on fine with good pad contact and works great.
    I can post photos if the above is not clear.
    The reason dogs have so many friends is that they wag their tail instead of their tongues.
    Quote Originally Posted by steve47co1
    Pics would help. There is no problem using some thin washer to lift the caliper a little if pad contact is not perfect.
    May 2005
    Photos
    MC,
    Thanks for the quick input.
    Here some pics of how I set it up. I would rather not use washers if at all possible.
    Any ideas?
    Reputation: ThePunisher's Avatar
    Feb 2006
    what kind of Lyrik is that? never seen one with an air valve at the bottom like that.
    May 2005
    Lyrik 2 Step Air
    Just a plain ol Lyrik 2 Step Air.
